thespfxman
- March 4, 2023
- Rancho Mission Viejo
- 2013 Ford Explorer Sport
Hello fellow 'splorers... first time post here and I'm at that point surely many of us have become, when you gave it a shot after buying an OBD scanner and jumped to conclusions...
Specs:
Symptoms:
OBD Codes (also see screenshots) Note: This reading was taken after the below repairs were made and I did NOT clear any codes (oops? idk)
Thank you for reading to this point, if you have any solid (grounded in experience) suggestions as to what I may check, clean, tighten, repair or replace... PLEASE let me know.
Specs:
- 2013 Ford Explorer Sport, 3.5L Engine w/ Ecoboost
- 107K miles
- Has had all outstanding recall services (think just two: rear suspension toe link and something about exhaust and CO2 levels leaking in when idling)
- No engine mods of any kind
- Driven moderately-aggressive but pretty mellow 60% of the time, however I am a habitual down-shifter in favor of engine braking (Side Q: Can this cause long term damage?)
Symptoms:
- Slow to start, about 3-5 seconds turning over before ignition
- Flashing check engine light
- Loss of power and engine shuddering when moving at high speeds and in high gear
- Low gear high RPMs allow for more power
- Heavy exhaust smell but mainly gasoline smell in cabin of car, seemingly emitted from engine bay
- Black exhaust when accelerating (noticed when AAA drove up on a flatbed)
- White vapor or smoke that quickly dissipates out of exhaust pipe when in idle
- 3 Confirmed Codes
- P00C6 Fuel Rail Pressure Too Low - Engine Cranking Bank 1
- P0151 O2 Sensor Circuit Low Voltage Bank 2 Sensor 1
- P0304 Cylinder 4 Misfire Detected
- 2 Pending Codes
- 2 Permanent Codes
- 4 Powertrain Control Module Codes
- P00C6-00 Fuel Rail Pressure Too Low - Engine Cranking Bank 1: No Sub Type Information
- P0151- O2 Sensor Circuit Low Voltage Bank 2 Sensor 1: No Sub Type Information
- P0304-00 Cylinder 4 Misfire Detected: No Sub Type Information
- P0316-00 Engine Misfire Detected on Startup (First 1000 Revolutions): No Sub Type Information
- Replaced all 6 coils AND spark plugs, cylinder #4 did have a heavy gasoline smell and the plug removed was soaked.
- Replaced Bank 2 Sensor 1 Oxygen sensor (I think?**)
- After the repairs were made, I did not clear any error codes from the car's OBD. I am not sure how this may impact the most recent OBD codes above, which were taken AFTER these repairs were made.
- **The oxygen sensor I replaced was on the very lower left of the engine when facing it from car front and I was able to do it with relative easy standing in front of the car. Are there other possible Oxygen sensors I should also replace, or is this NOT the B2S1 sensor? Why would this oxygen sensor error persist after the remairs were made, should I have cleared the error? Would the fuel rail issue or something else cause the "Low Voltage"? Does "Low voltage" imply a faulty sensor OR possibly faulty wiring somewhere?
