Wesley Stout
- November 17, 2019
- Cookeville
- 2015 Explorer XLT 4WD
We purchased a 2015 Explorer a few months ago. The cooling fans only work on high when the AC compressor is engaged. I believe low speed fans should come on when the AC compressor is engaged. That seems to be the activity on other vehicles and my F150 also. I can command the high speed fans to come on with Forscan, but not the low. I can go straight to the relay and make the low speed fan work. I am guessing there is a problem with whatever sends the signal to the fans or a switch on the AC etc. Just wanted to see if anyone else has had this issue and might have some pointers. Thanks!
