2016 Ford Explorer limited . Currently have a A11 with version 3.10, no problems. I tried updating to A13 ( 3 times, 3 different Amazon vendors) . Failed, does not recognize. Any suggestions?
I had the same issue on Amazon going from an SD9 to SD13 card and just returned it. The SD9 card I purchased on Ebay worked well, but SD13 card will not work. It's been a long time, but I also assume the latest software update is still 3.10. This is what one seller asked on Ebay when I asked if the SD13 card would work in my Explorer:
"Hi,
Can you please let us know the info below.
1. Determine your SYNC Software Version
a. Go to your vehicle, on the home screen press the “settings” icon
b. Press the “Help” button
c. Press the “System Information” button
d. The third line displays your software version
e. Record the numbers after “CCPU S/W Version”:
__. __ __.__ __ __ __ __
f. Record the Map Database Version: __ __ (i.e. A4, B4)
2. Look at the last five digits of the CCPU S/W Version and choose one of the actions below.
If your software version is greater than or equal to 12285, this update is compatible.
If your software version is 10337, 11038, 11063, 11081, 11134, 12023, 12156 – please visit owner.ford.com or owner.lincoln.com to update your SYNC software.
If your software version is 10212, 10308, or 12058 – your vehicle requires a software update from a dealer.
Best Regards,"
