2020 ST Rear Suspension Adjusters | Ford Explorer Forums
BlackJack21
Vancouver, BC
2020 Explorer ST
I am about to start tinkering with my 2020 ST suspension settings. I feel they are less than optimal as there is excessive bump steer and lack of wheel return on hard cornering. To this end I have purchased camber adjusters for the rear suspension from McBay. Has anyone been down this road and have suggestions for front castor/camber/toe and rear toe settings?
The camber adjusters stock are perfectly fine and adjust perfectly fine. Unless you’re willing to take a toll on tire wear, keep all the settings stock, and start upgrading suspension parts. Rear sway bar, vertical links, rear toe links, will completely transform the handling. Check out the suspension section on my modding guide for all the info:
Explorer ST Modding 101 Guide
here are a couple more things that will improve the handling. Both are from Steeda.
If I recall correctly Rear subframe bushings won’t change handling at all, launching it helps a lot though.
