rusto
- May 4, 2011
- Whistler, BC
- 2000 XLS
Hey Guys,
I've got a 2000 Ford Explorer XLS. I was driving today up a bumpy dirt road (not in 4x4). When I realized I hadn't accelerated in a while, I put the car in park and the idle speed was sitting around 3,000 RPM. Turned the car off, checked the throttle cable was returning correctly and it was. Restarted the car and it was still idling at 2800 -3000RPM.
I disconnected the battery, which when you restart the car re-calibrated the idle speed to the correct RPM range. On the way down the hill it happened a couple of more times, instead this time I turned the car off, and restarted a minute or two later which changed the idle speed to correct position again.
It seems to be happening when the road got fairly bumpy, so I'm thinking it could be a loose connection or similar, but I have no idea what would cause this?
Any help would be much appreciated
Shane
Shane
