explorer4453
- May 21, 2010
- Ohio
it is turning off, no signal comming from left front wheel,I will be checking the abs speed sensor and wiring. I also need to locate the PCV valve because there may be a small leak in the vaccum hose causing the computer to make the vehicle run rich and show the rich codes as it has been doing for the last several months.
