daryl85
- August 29, 2013
- michigan
- 1998 ford explorer sport
I have a 98 ford explorer sport , 4.0 4x4 with 213000 miles.. for some reason I can't figure out is that my coil pack randomly loses power , truck turns over like its going to start but the coil pack won't spark , I let it set over night and it will start just fine 3-4 times and then quit sparking again , put new coil pack in , that didn't help , took the can sensor out & cleaned it cause it was pretty crummy , still get same results ...no check engine light either , code scanner says its working fine and throws no codes , any one framilliar with this problem ? Its my only vehicle , and I drive 60 miles round trip everyday for work..need to get it figured out asap if any one can give me more ideas to check I'd be gladly appreciatave
