macoffma
- November 13, 2002
- indpls., in
- 99 Mountaineer
It's a 93 4.0 with about 80k on it. About October I started noticing that the engine sounded rougher at anything greater than an idle--it was much throatier than it ever had been before. When I would drive at higher rpm's, especially when I would be on the interstate above 60 mph, the truck would almost automatically start to violently shake back and forth, and I had very little power. I was also getting the rattling noise from the engine, especially going up hills or when accelerating at the higher speeds.
I replaced the air filter and thought I had cleaned the MAF sensor, but there was no change in performance. I then replaced the spark plugs, which had never been changed. I replaced them with the Motorcraft plugs. This caused a dramatic improvement. The vehicle would still shudder at idle, but interstate driving was much improved and the power had returned. The engine was still much throatier than I remember.
About a month ago, the symptoms returned. I had read other posts on the board that suggested changing the wireset, so I did this and the situation again improved. The car would shudder at idle, but the violent shudder at high speeds was gone and so was the rattle.
In the last couple of days, though, it seems to have gotten worse. It seems like each thing I've done has made it better for awhile, but it seems to eventually regress each time.
I noticed there was a bit of oil on the plugs when I replaced them. Also, the transmission has become much slippier since all this started (which I think may just be a result of the power issues). Most strangely, the problem seems to be worse the warmer the air is outside. We've been pretty cold here this winter, but as soon as it warms up it seems to make the performance worsen.
Thanks in advance for any help!
