Anyone recently have any 4.10 gears installed on an 02-05? There’s some old threads but not really sure what parts exist anymore if they do and Google comes up with nothing so figured I’d ask around here
don't know if you're on the 3rd gen facebook group much but it's much more active than the 3rd gen forum here, you'll probably have a better time getting answers
Give Yukon a call and ask for Tate ext 5573, he will have a laundry list that you'll need to go to 4.10, lifetime warranty if you blow them up for any reason.
The only gears we use on our projects work and personal vehicles.
Yukon Gear & Axle high performance ring & pinions set the standard for quality. Yukon designed the gear tooth surface finish to reduce friction and heat, and use high grade steel in both the ring & pinion, with fitment designed to OEM spec
