muscleclone
- January 9, 2013
- Maryland
- 2003 Explorer Limited 4.6
Hello,
I have disconnected all parts that are required to drop down the transmission. I also removed a total of 7 bell housing bolts including the two on top of the bell housing, 4 fly wheel bolts, and the starter. Somehow I can't seem to separate transmission from the engine. It seemed like there is another bolt or something that holding it back, but I don't see it. Not quite sure if there is something else that I need to remove.
When I use a pry bar from the bottom I can see it separate a little bit, 1/8 in or so. I don't want to force the pry bar too hard and break something unless I know for sure it is all clear.
Any suggestion would be great.
Thanks
Thanks
