CommandPresence
- January 3, 2012
- Massachusetts
- 2018 Explorer XLT 3.5L NA
So initial thought is the torque converter rattle. I'll break it down for you. Noise is NOT there while moving, or in neutral. Sitting idling in drive, sometimes park, reverse, 3 2 1, rattlerattlerattle loose marble from starter area underneath the car. RPM range for the noise is from 7-900, then disappears completely. Let off, let it come back down, lightly hit throttle, it re appears. No performance issues or shifting issues at all. Would this still be a torque converter issue with problem described, as no issues while moving or in such a small rpm range? Seems when the drivetrain shifts when put into gear it's more prominent. Heat shields 'seem' to be all intact as i inspected all with flathead. Any thoughts? My understanding with torque converter is it would be in a broader range of rpms and also heard while driving until it locks. Possible starter need shimming? shimmed improperly?
