4WD only works once the battery cables are disconnected. | Ford Explorer Forums
shukapuka
'02 Explorer Sport
'02 Ford Explorer Sport 4WD High & 4WD Low dashboard icons aren't illuminating. If i disconnect my posative battery cable and then turn ignition key and then reconnect cable i can sometimes get the icons to illuminate, which allows me to have both 4WD High or Low. Both Low & High operate fine and there is no problem with engagement or disengagement.Once the vehicle is shut off the icons will not illuminate again until the above mentioned procedure is repeated.
It could be the 4x4 control module.
