4x4 high light flashes for other reasons not related to 4x4... wheel speed sensor for instance will cause the 4 high light to flash, which would throw a code for a wheel speed sensor.
I used obd2 as a generalization. I'm fairly certain everyone understands what I'm talking about without further complicating things. I apologize if I have upset you.
Need the codes. Get it on a good scantool. And if you can get some live data check the front & rear shaft speeds while you are at it. Check the main electrical connector. Check related fuses (see manual).
