4X4 High Flashing | Ford Explorer Forums
4X4 High Flashing
dkingcan
Ontario Canada
2002 Explorer Limited V8
To all that have a flashing 4X4 high light flashing.Do not assume that it is your control module.I purchased a new module and still had the same problem.After searching the forum here a discovered it could be many things.Mine was the ground wire right at the connector of the shift motor.Ran a ground from the frame to the broken wire and all is well.I always had 4X4 low just no high and auto.Low must use a different ground.So if your 4x4 high light is flashing 10 times and then out for 2 minutes or so,i would first check the wires at the shift motor connector before purchasing the module.
2002 Ford Explorer Limited 4.6 V8
