4x4 trouble!?!?! | Ford Explorer Forums
4x4 trouble!?!?!
surfer1158
Denver, CO
1991 XLT
So i took the exploder for an all day four wheeling trip and it handled like a beast. I was stunned at how well it did. anyways about 4 or 5 hours into four wheeling i noticed when i hit a big bump the 4x4 and low gear lights started to flicker. I knew that wasnt good and immediately slowed down to take it out. I hit the 4 low button and i heard it come out. then i hit the button to take it out of 4x4 and i only heard one click from the relay instead of the usual four or five, but the 4x4 light still went off. I said some foul words and accepted my loss. I tried hitting the 4x4 button again and this time i heard the relay click six or seven times and the 4x4 light come back on. then i hit the 4x4 button again and only heard that one or two clicks and it didnt come out of four. i tried a few more times. Then i turned the car off then on and tried again, and somehow it came out when i hit 4x4 but i still only heard 3 clicks. Anyways when i got back the next day my dad was driving it down a main street when he heard BAM!:eek: like the transmission just dropped and some grinding. He immediately pulled over and played around with the buttons and backed up and he said the grinding went away. Then today i reset the 4x4 computer and the 4x4 went in fine with a little bit of grinding. Then when i went to take it out of 4x4 i got the dreaded 2 clicks. So i tried backing up, drove it around the block, backed up again, started driving real slow again BAM!:eek::hammer: It sounded like the transmission dropped but immediately i noticed it was out of four. I stopped the car walked around and everything was still there. So too my long drawn out question, what the hell is going on??:help: I really want to go 4 wheelin again but cant afford expensive repairs. Whats going on???
Sounds a lot like what my BII did when I had mismatched tires on it (same size, but the front two were a different manufacturer than the rear two). The slight size difference between the two sets caused enough tension in the drivetrain to temporarily "seize" the t-case. In that case, I simply replaced the tires with a new set of four and it started working right again. It sounds to me like, be it tires, or terrain, or whatever, you're experiencing drivetrain windup.
hmmmm after doing a couple hours of searching and reading im coming to think it might be the shift motor not disengaging it out of 4 then that plastic stopper all of the sudden comes free, but im still wondering what would cause that boom??:rolleyes:
bump: can anyone give me some more advice here before i pull the shift motor off??
