5r55e questions | Ford Explorer Forums
5r55e questions
paul302289
97 ford tramsit
Hi, can anyone out there help. I have posted a similar question in the past and got no answers.
I am fitting a 4.0 sohc motor into and English ford van, I would also like the fit the trans.
My problem is I have a 5r55e.
I will be running the motor on Megasquirt and will loose trans control. Can anyone see a way around this, I have no objection to fitting a switch or two on the shifter or dash to select fifth gear and overdrive and lock the converter. Thanks ,Paul
