60R16 on Ford explorer 2002 | Ford Explorer Forums
robbiwan
2002 explorer
I made a mistake of buying second hand winter tires. I am wondering if they would fit?
60R16 on ford explorer 2002? Help :D
We need more info than 60r16. For instance I'm running 265/75/16 with no lift.
We need more info than 235 60r16. For instance I'm running 265/75/16 with no lift.
Hi Tyler, thanks for the reply. It is a Ford explorer 2002 stock no modifications. The Tires are 235 60R16
They will be smaller than factory by a good bit........
Yes they will work but they will be roughly 2.5" smaller in diameter than stock and a little skinnier. If your 4wd make sure tread wear is the same on all 4 second hand tires.
You'll also be going slower than what the speedometer says and your odometer will not be accurate. I'd relist them and find the proper size.
