'91 Gas Tank Front Strap mount (bolt in) Anyone have a diagram/pic of this? | Ford Explorer Forums
Yukonvic
Hey Guys/Gals,
Does anyone here have a picture or diagram of the front mounting strap bolt in area for the gas tank? I would like to know where it bolts in...I know I took it off and unscrewed it but it has to go back on and I do not see the attaching treaded area to screw it back up. If you do have any pics or diagram pls send it to Yukonvic2@yahoo.com or post a link/or attachment. Thanks.
Another questions for you, has anyone replaced the middle brake hardline that runs from the rear differential (brass/rubber hose) up to the master cylinder? Does the gas tank have to be removed for this install of a new brake line and what is the diameter/size of the brake line?
Thanks...I dropped the tank to replace the fuel sender/pump do to excessive rust and when we got it all back together...the damn mid brakeline burst...at the rear most connection just above the fitting! ACK! :fire: Talk about pissed! Well...any help is appreciated...thank in advance
Yukon
