I blew the tips off my bosch plats (not the the same as 4's). The truck would hesitate, and buck under full throttle acceleration. The place I took it the truck in for repairs put it on a scope, and said it had wierd things going on. They pulled the plugs, and replaced them with with a different set of platinum's. Problem solved.
They showed me the plugs. Let's see if I can represent it right here:
| | ^ <--- this had blown away.
(ok, all attempts to format it correctly failed.)
Where the "this had blown away" points to, is a itty bitty little platinum dot on the Bosch Plat's. On 5 of the 6 plugs, it was *gone*.
Understand? So try different plugs.
