TheJMan
- April 5, 2003
- Scottsdale, AZ
- 2009 Mazda 3 Hatchback
My brother's 93 Explorer had the check engine light come on today. I took it to Checker and had it scanned and it gave me the following codes:
136- Something about the system being at the lean limit
238- Electronic Ignition Coil failure
If the engine is turned off and then turned back on, it will run fine for a few moments, and then starts idling erratically and the check engine light will illuminate. It bogs badly when accelerating at around 1200 RPMs, and then surges. It also sounds like there is a fast tapping noise coming from the engine at higher RPMs.
Also of note: this car was in a shop today and had the A/C compressor replaced.
Has anyone had any of these codes before and if so, how did you fix them?
