Nick2x2
- March 5, 2014
- Location
- Hemet California
- Hemet California
- 2010 Explorer 4x4
Followed the troubleshooting chart and ended up at the starter..
When ignition is switched to start there is a single "click" then nothing. Vehicle is a manual and was able to start and run smooth when bump started. I've tested up to checking voltage at pin 85 on the starter motor relay and found source voltage. Now before i pull the starter and inspect it on this 100 degree day does anyone have any ideas?
Note: When the engine is running and the ignition is turned to crank, the starter doesn't engage and grind against the flywheel
