lvgunner
- June 19, 2001
- Las Vegas moving to Illinois
- 94 XLT 4X4
94 Explorer V6 w/AC. I've searched the forums and found nothing describing my problem I have very little or no heat in the cab. All the cables are attached, but for some reason there is no vaccuum getting to the heater core bypass valve. Even if I use a vaccuum pump on the bypass valve and move it manually I still get no heat in cab, but the inlet and outlet house heats up. Is the vaccuum to the bypass valve also used for a valve that directs air over the heater core? If so where is this vaccuum line and how can I troubleshoot this? I just moved from Las Vegas to Illinois and it is freezing here.
