mauser1111
- November 25, 2008
- Stewartstown, Pa
- 1994 Sport
Im at 45 mph, the speedometer will then climb up to 55mph or so then fluctuate back and forth between them speeds. It is cold outside this mtime of year. I pulled the speedometer gear out of the trans. case, and checked it, it was fine. Is this a sticking cable problem? Is there an easy way to lube these other than pulling the dash apart? Thanks for your responses.
