94 xlt engine flutter at speed or exceleration | Ford Explorer Forums
bigku1
Columbus, OH
94 XLT
Here it is: Rough idle but smooths out somewhat at about 50 0r 55mph, the when it shifts last time, engine flutters and car shakes, but if I let up on gas or give it more gas it seems to smooth out again, its almost like at a certain speed or rpm it does this.
I am getting no codes at this time and have checked plugs and wires. Any help appreciated.
Did you use a meter to check the wires or just visual inspection?
You could try some seafoam as well. How to in the link in my signature.
Did a visual, but will check with meter.
Replaced coil pack and one changed plugs, problem solved for time being. It appears that the last time I had plugs changed, one didn't get changed and it was fouled very bad.
