95 ex, chasing a misfire issue.... | Ford Explorer Forums
pitbulldell
Orlando,Fl
95 XLT
95 ford Ex. when I crank it up when cold it will start just fine then after a minute or 2 it will stall. Mashing the gas will not do anything to stop it from stalling out. After it stalls you can crank it right back up and sometimes it will do it again or sometimes it will run just fine. Now on top of the other issue it has developed a misfire. got it scanned and it came back tps and coil pack misfire. So I changed the coil pack and the tps. plugs, and wires. It still does the cold start stall out and the misfire is still there. But the misfire is only there when in drive and driving along. If you put it in Neutral while driving it will rev with no misfire soon as you put it back in drive bad misfire again or if in park rev with no misfire. Put it in drive and mash the gas to pull off and there goes the misfire again.
Well, sounds like you can rule out an ignition side misfire. Perhaps you have a fuel problem (injector/regulator) or vacuum leak.
