95 lift help!! | Ford Explorer Forums
95 lift help!!
Tat2dExploder
Monroe, Mi
'95 Sport 4.0
I'm about to do TT and shackles, but i would like to fit 33's on it, is there a 2in body lift or can i even do one?
You can use a 2" or 3" body lift from a 95-97 Ranger. It will take a tiny bit of modifying to the steering extension (if you do a 3", no extension in the 2") and you'll need to pick up a couple more 140mm bolts. Tons of people here have used the Ranger lifts on their Explorers with great success. Search around because there are a couple excellent write-ups too.
Good luck!
EDIT: Plus you'll need to A) make your own custom bumper brackets or B) Buy the brackets from the 98-00 Ranger kit. :cool:
Or if you're 2wd you can use 3" lift spindles in the front and SOA (spring over axle) the rear.
thnx much for the help fellas, i thought i was SOL with this truck
