96 Aerostar. E-4WD jumping & popping while turning. | Ford Explorer Forums
zldavis
Raleigh, NC
1996 Aerostar 4.0L E 4WD
My 1996 Aerostar has an electronic 4WD. Recently while making left or right hand turns while slowing down to about 15mph to turn the front end makes a violent jumping/popping/thumping which shakes the front end. After inspection of the front end we noticed a bracket was broken which connects to the transfer case. We had the bracket welded back together thinking this was the problem, but the jumping/popping/thumping continues. You can feel it under the drivers side. Also when you switch from drive to reverse, you feel a hard thump which seems to be related.
Has anyone had this problem or know what it might be?
I checked everything except for the motor mounts.
