justin321123
- May 11, 2009
- Delaware
Ok, so the other day driving home from my aunts the X drove fine, we get to a red light an stop, green an we start to across the intersection an all of a sudden the RPMs go up to 6K an the X isnt going anywhere. Seems like it went into Neutral. My mom ended up using the van an pushed the X to the house so it didnt need to be towed. SO now i am in the process of trying to figure out what happen. Here is what I have found out so far.
1996 XLT 4x4 V6 190,000 miles
1- No Drive, Reverse 2or 1 in 2wd or 4wd
2- trans fluid is clean an filled properly.
3- No odd noises from the trans
4- every once an a while the speedometer wouldnt work(driving at about 60 an it would go to 0 an then back to 60 start falling an then back to 60 again)
I have not a clue as to what happen an need some help. If the trans went you would atleast thing not all the gears are gone. My friend has a 82 stang and he didnt have drive an he just drove around the devolopment in R. I doint have any gears at all.
Thanks in advance.
Justin
Thanks in advance.
Justin
