RojoBlanco
- September 3, 2010
- AZ
- 96, 94 Ex, 01 Mtn
Fellow Explorers: The connector to my IAT sensor came apart which caused the "Check Engine" to light up. I verified that the sensor was good using the ohm test in the repair manual before I stuck the connector back together. I have hooked it back up but the "Check Engine" light will not disappear. Is there a way to reset the system so it goes through its normal start up procedure and then shuts the light off automatically again? I have gone through several start cycles thinking that would clear the "Check Engine" icon. Any ideas? Thanks. David B.
