steve300
- August 31, 2004
- Castleton, VA
- '97 XLT
Apologies in advance - I am a totaly newbie to this site, to Explorers and to automatic 4WDs in general.
I have a used '97 with the Auto/4HI/4LO switch. Several months ago it started shifting itself into 4WD during sharp turns to either side. During one such self-engagement, the main shaft inside the tranny shattered while turning onto a busy highway. I had the transfer case, clutch and tranny replaced. Within a few months, the same problem is recurring. No lights flash, no real noises, just severe jerking back and forth as you turn and it goes into 4WD. Problem is intermittent but ongoing.
A Ford diagnostic reports no computer/sensor problems so they want to replace the same drive chain again. Six dealerships and two independents have either different answers or don't know. Fluids are clean and full in the cases.
The X also has a 'check engine' light that turns on when you fill the gas tank and then drive it enough to warm the engine (Ford can't diagnose) and both reverse lights have stopped working. I assume these problems are unrelated however they are occuring at the same time.
Thank you in advance for any help.
Steve300
Steve300
