97 Explorer V-8 5.0 Spark Plug Replacement | Ford Explorer Forums
Chrisrod2016
Location
Texas
San Antonio, tx
97 Explorer XLT V-8 5.0
I just bought this SUV it only has 104,000 miles on it and I put a Flowmaster on it too. It is has been garaged for about 10 years. Can you please tell me what is the best spark plugs I should put on that will give me more power and mileage with out jeopardizing the engine itself.....thanks inn advance.
I've always used the factory motor craft plugs. A "designer" plug won't increase power or mileage.
Thanks for the reply. I read the stock plugs were Motorcraft? And if they are is copper or platinum better
I believe they are copper, Platinum in theory will last longer assuming no engine issues such as bad valve guide seals. { if they are getting fuel or carbon fouled they will both fail prematurely) Platinum plugs only give performance benefits if the motor was designed specifically for them. Hope that helps
Thanks for joining
Tony
