98 3.0L Engine Replacement questions | Ford Explorer Forums
oilleak
Tampa, FL
93 XLT
I've got a 98 A/T 2WD Ranger with a bad engine. I've located a salvage engine (same vin code) from a 99 M/T Ranger.
1.) I'm assuming the only difference will be the flywheel - will the A/T flex plate bolt right up with no issues?
2.) More general question - can the engine be pulled w/o opening up the AC system? I've read that it can.
3.) Any time saving tips for R&Ring that engine? I'm thinking pulling it together with the transmission will be easier. Thoughts? Tips?
Thanks,
Often you can pull the AC compressor and carefully set it to the side while you pull and drop in the new motor.
