jimlas53
- September 7, 2006
- Fort Mill, SC
- 98 XLT
I just finished a complete rebuild of a 1998 4.0L SOHC V6 in my wife's Explorer. I replaced the timing chains, sprockets, guides, rings, bearings, all seals and gaskets, and had the heads surfaced and the valves done. I bought the Valve Timing Tools required to set up the camshafts properly. I've spent time on the Web (and especially on these forums!) to learn all I could about the timing chain/guide/tensioner issues with these engines. When I pulled the engine down, I checked and at #1 TDC, both cams alignment slots were parallel with the heads and below center line.
All through assembly, I followed the Alldata assembly steps, especially observant of the torque requirements, etc.
I also pressurized the oil system before starting to ensure no initial start-up bearing damage.
When I started it for the first time I had most cylinders, but not all of them. It was missing, and it sounded to me like a vacuum leak. I pulled the upper , then the lower manifold off, and found no problem with the o-rings. I started it again, this time noting that pulling spark plug wires on the left bank didn't seem to make much difference. Pulling the #1 plug killed the engine. I also noticed that after 5 minutes running, the left exhaust manifold was somewhat hot to the touch, but much cooler than the right bank. I've pulled the valve covers, and at #1 TDC, both cams slots are parallel to the heads and below center line. The intake and exhaust lobes are properly positioned for #1 cylinder in firing position, and the flag on the left cam is coming up under the Cam Position Sensor in the left valve cover.
I have verified the spark plug wiring (according to Alldata) and all vacuum connections.
WHAT have I missed????
Thanks for the help!
Doug
Doug
