98 MERC
- December 17, 2015
- Holland Michigan
- 1998 Mountaineer 5.0
So i have had my vehicle for 2 years and has always been a ***** to start.Really bad when its cold outside and i live in MI.If i let it sit for a week untouched and its like 40* OR below it takes like 5 key cycles on and off and just about burns my starter out to get it started ! lol.But the funny part is most of the time when the motor is warm she starts up with a couple key cycles.I have been plagued with this embarrassing problem for to long.I will go to the gas station and turn the vehicle off and fill it up and it cranks for ever and other times i turn it off and get back in and it starts right up with just 1 key cycle on and off.Its soooo random ! I have never had it start up right away ! EVER.
My mechanic thinks the pcm is bad but i would think a bad pcm would run terrible all the time and have no obd2 port communication.
I think its the fuel pressure regulator or fuel pump.
Or it could be the ECT sensor ? or the MAF sensor ?
Sometimes when it finally fires up after 5 mins of cranking, It smells rich out the tail pipe ! Hell i have even had it backfire out the tail pipe during starting before.
When she runs tho wooooo Its like a raped ape.
I even saw another mountaineer have the same problem and watched him cycle his key a couple times to get it to start up.
