98 brake problem...need help guys | Ford Explorer Forums
RangerForumGuy
Florence, MS
98 XLT 4-door 2wd
I recently changed the front pads on my moms 98 explorer 4-door 2wd. I had to replace the driver
side rotor b/c the pad had eaten into it really bad. But the other side was fine so I did not have it turned. I checked to see that the rotor wasn't warped and it looked good. Got everything back
together and it stops great right until it reaches speeds below 10mph then the brake pedal falls a bit and it fills like it slips and takes longer to stop??? I really don't know how to explain it. I have bled the brakes(all 4 corners) twice and the pedal fills tighter and the fade went away a little. Also sometimes it doesn't do it?? I replaced the pads on my 98 ranger without replacing/turning the rotors and it did the same thing for a little while and now it has stopped.
Any help would be greatly appreciated.
__________________
98 3.0 auto 4-door flareside
EXTERIOR: DJM 4/5 drop (5/7, with a few changes :-) ), Airshocks, 17x8 Chrome TSW VX-1, w/
Falken 255/40/ZR17's
INTERIOR:Color matched interior pieces,Sunpro mini tach, Racing pedals
MOTOR: K&N flat filter w/ cut air box
Throttle cable mod, 2 Chamber flowmaster turn down, Flex-a-lite Elec. fan, 180 Super stat., Hot
water bypass, Custom intake pipe, MAF mod, relocated IAT, Mobil 1 syn.
ETC....
It sounds like one of the brake (either left or right) is working better than the other which trigger the ABS. ABS works by sensing the rotation of the other wheels. That is why the pedal goes down a little bit and makes it a little bit longer to stop. The other (new) rotor might be be causing the imbalance with regards to stopping.
Good luck.
