98 Explorer Eddie Bauer electric windows | Ford Explorer Forums
rep0144
Kansas
1998 Explorer Eddie Bauer
I'm having problem with the window switches on my explorer the master switches all work but none of the other door window switches will work I have tried changing the master switch cluster thinking that the lockout switch was bad but this did not correct problem. Could there be a relay bad that the lockout switch controls? Any ideas?
Thanks
Russell
there is no relay for "lockout"... it is a switch and that's it. Meter is your friend. check for continuity when the switch is set for "non lock". If there isn't continuity across the switch then... your windows will remain locked out at other control. Odds are you have a broken wire in the driver's door post... trace / follow R/LB.
Switch has continuity I was hoping that I didn't have a broken wire but that was my next area I was going to check. Wish I could find a good wiring schematic sure would help trace wire.
Russell
good on the switch.... just follow the colored wire "leaving" the switch.... that's your problem.
