alex95
- August 11, 2014
- Belton
- 98 Mercury Mountainier
ok so I have a 4.0L 4WD 1998 Mercury Mountaineer, the issue is when you put into 4Low it wont come out (yes I have it stopped and in Nuetral). The front end is locked in because there is bind at slow speeds, BUT it isnt in low range. I am unsure if it does this in 4Hi also, if so it will let you into 4Low, but then it wont com out of 4 "low". this started after a simple engine swap (Factory ECU was retained) could this be a connection issue? or just bad luck?
Everything but the engine has 298,000 mi on it
