skfullen
- January 25, 2006
- Houston, TX
- 1999 & 2000 Explorer XLS
I have an '00 Explorer that had this same problem, and a few tankfuls of concentrated fuel-injector cleaner seemed to do the trick.
I have a 99 XLS with the same 4.0 (OHV) exactly like my 2000 except for the color and trim. About 2 months ago it started to miss while sitting at a red-light for an extended period of time. Not really a miss, more like a jolt. At first I thought someone had kicked the bumper on my car and I looked around to see what had happened. Then it did it again. After the jolt, it runs fine for. It could do it again within seconds, or it may not do it again for days.
It runs great while accelerating and at all constant speeds except between 30mph and 40 mph. At this speed, it misses intermittently. Step on the gas and it smooths out and runs like a spotted ape!
It has 85,000 on it and was I just replaced plugs, wires, fuel-filter, as general maintenance. A couple hundred miles later these present symptons developed. I replaced the IAC valve thinking it was the culprit. It did not help. I took the IAC and MAF off the 2000 Explorer and put them on the '99. It made zero difference and the symptons continue. I've done the Sea-foam treatment twice and Deep Creeped the throttle body. It seems to help some, but within days the symptoms have returned. I've also ran two cans of Seafoam through the tank with 20 gallons of gas.
Does this sound like a coil-pack or perhaps an injector? The same symptons plagued my 2000 for about a month, but a few tanks of injector cleaner fixed it, and that has been 10,000 miles ago and it hasn't returned.
I'm open to suggestions and advice.
Thanks for your answers...this is an awesome sight.
