99 explorer keyless entry | Ford Explorer Forums
j7logan
i bought my truck used and the dealer didn't have the keyless entry remotes. how do i check to see if my truck has this option? and has anyone had an experince buy the remotes off ebay? i don't feel like spending an arm and a leg at the dealer.
The Ebay remotes work good! 2 for about 30 bucks, can't beat it.
1. You can call your local dealer, parts department. They should be able to tell based on a VIN #
2. You can follow those easy steps to find out
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN (do not start the engine). If all doors lock then unlock to confirm programming mode - you have the system
