EchoTwo
- December 27, 2017
- Long Beach
- 1999 Explorer XLT
Hey guys, I've been having a problem with my truck for a while with running rough during idle. I checked the sensors, took it to the shop to get an inspection, nothing. i was told it was a vacuum leak, one day when it was getting rougher than usual I hit the gas just a little and finally my engine light came on. Ran the code and it turned out it was an Upper intake manifold gasket (I think) and got it replaced...no change. When I got the gasket replaced though the shop told me I had a misfire in cylinder 1, couple weeks later I took it back to get that diagnosed. They say its the spark plugs and needs a tune up, so they replaced all the spark plugs and spark plug wires....the old ones were pretty bad.
So now that the setup is all done, my truck is now running even worse, I'm losing power when I hit the gas, the engine shakes pretty bad and sometimes it sounds like its revving up and down a little, it's even stalled twice but not on the road. I do not have a check engine light, just like before. Any ideas what it could be? I will also note that while actually driving the truck runs fine, it's while I'm stopped, and when I first start to take off from a light or something.
Thanks for the support!
