A/C & Heat only coming out of defrost area of dash - 2008 explorer | Ford Explorer Forums
94Fexplorerxlt
VA beach VA
2008 Ford Explorer XLT
My A/C and heat are only blowing out of the defrost area on my dash . I don’t hear any weird noises or anything , blower motor is working fine sounds like it always has . Does anyone know what this could and or probably is ? 2008 explorer V6 XLT - 206k miles on it currently . Ive heard chatter about blend door stuff for these years but always have heard people mentioning weird clicking noises etc .
Yes it's the center blend door arm that has come away from the plastic. If you remove your glove box, shine light about center-high behind vents & operate vent selections, you will see the offending arm & piece it's supposed to be attached to in question.
I tried to tackle last year with incorrect tools, can't get to it. Bought a 1/4 inch base long drill bits for my impact to put extensions on it. Can drill a small hole in plastic arm & basically put a 1/2 paperclip to hold together.
Go on YouTube & search "2006 2007 2008 explorer AC through defroster vents" and a few videos will pop, a combination of 2-3 will get you to where you need to be to do it. Hope this helps.
Chris
Chris
Thank you very much I’m going to look into all that
This is what I did on my 07. Drilled a hole in the tab and used a tie wrap. All done through the hole created by removing the glove box. Progressively tighten the tie wrap so that it's got some slack in it and doesn't overextend. I have a movie of it working but don't see how to post it.
Thanks mine was broken much more than that so I couldn’t drill a hole large enough without breaking the remaining plastic so I drilled a tiny hole and used 16 gauge tie wire and fed it through and then twisted the ends together tight with a pair of needle nose pliers . It’s working great now
