Scout3
- August 19, 2010
- Orange Park. Fl
High Everyone,
Pretty new to this forum and want to say hi and thanks for the help you have given me. I bought a 1997 XLT from a friend of mine for my son about three weeks ago. It is hi mileage but it looks almost new. My friend is OCD about his stuff and takes extreme good care of everything. Anyway I bought it knowing the a/c did not work. He had already change just about everything except the evaporator. I found the blend door broken and just completed the door fix someone posted in the forum. That man that came up with that deserves a medal. That part works great now. Vacuumed down the system for about two hours and leak checked for an hour more, all looked good. I have a question on freon quantity for the 4.0 SOHC. The sticker on the hood says 1lb 14oz. I have a book that stated 1.38 lbs and I found a source on line that said 22 oz. I have a case of 12oz cans. I went ahead and started charging the system. It took two 12oz cans to get the compressor to stop cycling at idle and temps in car were still in the 80's. At 2000rpm it would cycle again. Added almost all of the third can ( estimate total 33oz seems like a lot) it does not cycle at 2000 rpm anymore and air temp will be 48 degrees. At idle temp creeps up to 58 degrees. At 2000 rpm High side is 275 and low is 30psi at idle about 700rpm high side is 250psi and low side is 50psi. Outside temp is about 90 degrees. I wonder about the temp creeping back up to 58 degrees at idle. Any a/c gurus out there that can give me some advice. Thanks.
Ed
Ed
