A couple Questions | Ford Explorer Forums
A couple Questions
joe_s_d
San Diego, CA
'00 XLS 4X4
Hey Y'all
I just bought a 2000 Explorer XLS 4X4. I promptly took it offroad the day after i brought it home and all I can say is wow! Other than ground clearance issues it is a more capable rig than my old 86 bronco. I am planning to do a 2" torsion twist and add shackles to the rear to partially fix the ground clearance issues but other than that Im keeping it stock sans the stock size A/T tires that are on it.
I bought the truck to go wheeling on weekends but it still pulls daily driver duty (160 miles a day).
My first question is are there any weak links in the suspension or drivetrain? what should I keep a close eye on? and what spares should I take with me when I go wheeling? Other than the obvious tool kit, U joints, tire patch, etc. I plan on doing Ocotillo Wells, Johnson Valley, Big Bear and a bunch of other So Cal spots regularly and let me tell you nothing is worse than a 10 mile trek in the desert cause your truck spit out the driveshaft somewheres.
The second question is my 4wd selector says "Auto" "High" and "Low". Does this mean the truck is full time all wheel drive? It didnt come with a Manual and its hard to find info on the internet about the 4wd options on these trucks. I know I cant, no matter how hard I try spin the tires on the street and when i had it in the dirt it was in High lock (I hadnt really thought about it at the time). It is an XLS but it has about every option available for the XLS for that year. I like it because it has all the creature comforts on the inside and no chrome to polish on the outside.
The Auto, High, Low doesn't mean it's full-time AWD. What it means is that when the control trac senses it needs to, it will automatically put the truck into 4WD for you. If you search for "brown wire" mod, you'll find out how you can disable this so you can have a true 2WD.. you know.. for burnouts and stuff.
I think by 2000 Ford had most of the problems worked out. Just do what you can to keep that tranny happy. A cooler would be nice along with flushes often. Take CV shafts with you (although it would be a little work to swap one out on the trail. Maybe a torsion bar (if you have the room). Welcome to the site! :D
Thanks for the help bro. Nice rig!
hehehe... section isnt jsut a wealth of knowledge, but a moderator here too... welcome to the site... and yeah watch the trannies... ford is notorius for not the best automatic trannies
