A little help for a newbie | Ford Explorer Forums
SpeedBump
Paducah, KY
98 Sport 4.0 SOHC
I have a 98 sport with premium sound, as was wondering, because it is cold and i do not have a garage, whether or not my X has a factory sub. I know it has a factory amp, somewhere behind the one piece rear plastic... Pass side I think, correct me if i am wrong. But not for sure on the sub anybody with some insight help me out please.
Hey man, if u pop out that little section in the back passenger side, the sub would be right behind it if you had one, u can't miss it. There are just little plastic clips u can pop outta place w/ a screwdriver, just be careful and not stress the plastic. Hope that helps
The little cubbyhole at the rear of the pass side correct ??
yea, its a lil black 8inch (i think) sub w/ a ring of foam around it if u have one
If yours has a speaker cover resembling this, them there is a subwoofer behind there, unless someone took it out. If in that spot you have a cargo pocket with net, then there is no subwoofer.
ok thanks for all the help. It is official, I have no factory sub. Which is fine by me all the good reason to install an aftermarket one. :D
