A little help please with hard wiring | Ford Explorer Forums
sixfootpeter
Cape Cod, Mass.
'05 XLT
Can someone tell me which wire to use and where it is located to hardwire my 5v Sirius power cord? I am unable to find a '05 wiring code and color chart. Thank you.:rolleyes:
Radio 12v: white/yellow + radio harness
Radio Ground: black/lt. blue - radio harness
Radio Ignition: black/pink + radio harness
Radio Illumination: red/black (dimmer) + radio harness
LF Speaker: org/lt. grn (+) - lt. blu/wht (-)
RF Speaker: wht/lt. grn (+) - grn/org (-)
LR Speaker: gry/lt. blu (+) - tan/yel (-)
RR Speaker: org/red (+) - brn/pnk (-)
Can't say for sure but the constant, ground, and ignition wire colors don't look right to me. If those aren't present, look for the following:
12v Constant: Green/Violet or Green/Black
12v Ignition: Pink/Black
Ground: Black/Green
Asked at a local shop about this this is what the guy gave me. Hope this works cause it cost me 5 bucks. good luck.
you didn't cut the cigarette plug off did ya?
If it's 5v then the plug itself will have the circuitry inside to convert from 12 to 5 v, so you can get a socket extension, cut off the plug, and hardwire it to any 12v source, then plug your cord there, hope this make sense...
