- February 2, 2002
- 1998 Mountaineer AWD
If your going to bypass the amp yourself, which you don't HAVE to, it can be powered and run door speakers, make sure you use the right wire diagram. These are the colors for the base level sound system, with no cd player, or factory sub. I'm going to post all the colors I had with an easy to follow diagram. Another way to figure it out is to use a battery. I used a AA but I think a 9volt would be fine also. You hold 1 wire to the + and one to the -. When you find a matching +,- one of the speakers will fuzz and pop. Those are the 2 wires for that channel. Yopu can also tell the wires polarity like this. You have to be able to see the speaker. If you connect it right the speaker should move forward, if it is out of phase it should go backwards.
