tac0meat
- May 29, 2000
- 91 EB 2x4
I lost my overdrive a few years ago. Everything else works fine, simply no 4th gear. Putting the trans in D or OD makes no difference, TC locks up around 55 like it always has, just no 3-4 shift. There is no hesitation or noise at 45 when it would normally shift into 4th or any indication of an attempted shift into 4th. OD acts the same as D, like they are the same setting. Selecting 2 or L will do just what think, either put the trans in 2nd or first and hold it there. I have had it rebuilt many times prior to losing OD, but beyond the loss of 4th gear, the trans has been solid, shifts fine.
I have been seriously contemplating a manual swap, but if a relatively easy/cheap fix will get my OD back, then it will make highway travel a bit more friendly until I get all the parts together for the swap.
My hope is its the 3-4 solenoid or maybe some kind of loose wire? I have had the fluid changed and it is clean (no metal shavings). I guess my question is, is there a way I can diagnose and possibly fix this in my driveway? and how would i go about determining if its a solenoid/something simple, or something that will require a rebuild?
