MisterCMK
- May 13, 2006
- Fargo, ND
- 1992 XLT
I just thought I'd throw this up incase somebody in the future has the same problems as me. I had to take my valve body out after a little piece of plastic from the screen/filter plug got stuck in my manual valve causing the truck to not shift through neutral. When I put it back together, the truck would not go into the right gear and the shifter was very vauge. Long story short, I ended up replacing the z-link, clip and washer and that fixed the problem. The z-link was worn where it goes through the rooster comb. After I got that whole mess sorted out the truck had no overdrive and reverse was slipping really bad. If I shifted it into reverse and gave it gas it would rev up and sound like things were slipping in the tranny. I finally fixed it for good this last weekend. It turns out that I mis-placed a check ball in the valve body. I will post a picture/scan of what I am talking about tomorrow but mis-placing a check ball was what caused all of my problems.
