tbe2002
- February 10, 2005
- Longmont, CO
- 08 Expedition Limited
Ok, well after fighting with my old transmission for along time it finally gave up. I decided to get a fully rebuilt tranny. It was suppose to a new pump, seals, clutches and stuff that was warn. I then bought a new torque converter to go with it.
Now we go to this past weekend when I tried to install it. I decided when replacing the tranny I would pull the engine too and replace the oil pan gasket and rear main and just freshen up the engine a little. So saturday I installed the engine first. I then added about a half a quart of tranny fluid to the torque converter and installed it. I spun it until is seated all the way back and turned it some more. It seemed to turn just fine. So we installed the tranny.
Right before we lifted it up for the last time, I reached in and made sure that the torque converter was still seated all the way back. (Which it wasn’t, it has moved) I then reseated it and made sure it was all the way back and it turned easily. We then lifted it up to the engine. The torque converter bolts lined right up no issues. We then tried to turn the engine by hand. I notice it was a little harder, but eventually moved. #1 mistake.
Fast forward to starting the engine the next day. I first added about 4 quarts of tranny fluid, I then attempted to start the truck. It cranked really slow and then I heard a clunk and it started right up. I proceeded to add more fluid, it started to spill out the vent tube. I was like humm. I then unplugged a cooler line and there was no fluid being pumped out.
I know I killed the pump and will have to get that replaced. My question is what did I do wrong, are there any tips or tricks to keep this from happening again? I plan to have someone just replace the pump. What else could be damaged from this?
Thanks for the help.
