GbMichael1972
- September 19, 2018
- Location
- Indianapolis, IN 46227
- Indianapolis, in
- 1993 Explorer XLT
I have a 1993 Exlporer XLT. recently. It has developed an issue. When I first start driving it in the morning it hangs in first gear, until the engine get to normal running temp. After that I have to let off the gas slightly to get it to shift into 2nd. I have change the fluid and filter as well as the vacuum modulator. And it added a bottle of muscle from Transtar Industries. It's not slipping in any gear every gear grabs when it hits reverse also is strong. I have check for vacuum leaks on the surface I'm good there. so unless it needs an internal vacuum leak around the intake manifold.
